Frankonia VKO Kombi
The Frankonia VKO Kombi device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia VKO Kombi:
The frequency range of the Frankonia VKO Kombi as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia VKO Kombi.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia VKO Kombi is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia VKO Kombi
- Google image search: Frankonia VKO Kombi
