GTEM TEM 500
The GTEM TEM 500 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the GTEM TEM 500:
The frequency range of the GTEM TEM 500 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the GTEM TEM 500.
Be careful changing these settings as RadiMation® is no longer able to verify if the GTEM TEM 500 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: GTEM TEM 500
- Google image search: GTEM TEM 500
