GW Instek GLN-5040A
The GW Instek GLN-5040A device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the GW Instek GLN-5040A:
The frequency range of the GW Instek GLN-5040A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the GW Instek GLN-5040A.
Be careful changing these settings as RadiMation® is no longer able to verify if the GW Instek GLN-5040A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
