Generic equipment
The Generic equipment device driver is a AmplifierVoltage, dips and interrupts generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Generic equipment:
The frequency range of the Generic equipment as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Generic equipment.
Be careful changing these settings as RadiMation® is no longer able to verify if the Generic equipment is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
