Genistron Inc. GCP-5120
The Genistron Inc. GCP-5120 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Genistron Inc. GCP-5120:
The frequency range of the Genistron Inc. GCP-5120 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Genistron Inc. GCP-5120.
Be careful changing these settings as RadiMation® is no longer able to verify if the Genistron Inc. GCP-5120 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Genistron Inc. GCP-5120
- Google image search: Genistron Inc. GCP-5120
