Hameg HM5012
The Hameg HM5012 device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hameg HM5012:
The frequency range of the Hameg HM5012 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hameg HM5012.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hameg HM5012 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
