Hameg HM8135
The Hameg HM8135 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hameg HM8135:
The frequency range of the Hameg HM8135 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hameg HM8135.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hameg HM8135 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Connection methods[edit]
USB[edit]
The Hameg signal generator can be controlled by RadiMation® by USB connection. This does require the installation of a specific windows driver provided by Rohde & Schwarz.
Note the following when setting up to control the Hameg HM8135 by USB:
The device comes available as a separate 'HAMEG Measurement Devices' category in the Windows Device manager. It is necessary to enable the 'Load VCP' option of the driver in the Windows Device manager. Then reconnect the USB again, and load the additional USB drivers.
Windows 11 support[edit]
The Windows USB driver provided by Rohde & Schwarz are not supported on Microsoft Windows 11 and newer. As an alternative the driver can be controlled using the hardware RS232 communication port of the Hameg HM8135.
RS-232[edit]
The following communication settings can be used:
Baudrate: 4800
Data bits: 8
Parity: None
Stop bits: 1
