Help.KnowledgeBase.AdvancedOptions
This advanced option determines if the 'Knowledgebase' button is shown on the 'Advanced Options configuration' window. If the value of this advanced option is set to True the button will be shown, otherwise the buttons will be hidden. The default value is True.
If the 'Knowledgebase' button is shown is also depending on the Help.KnowledgeBase.Enabled advanced option. Both options should be enabled to show the button.
Also see other advanced options that are related to the 'Knownledgebase':
- Help.KnowledgeBase.Enabled
- Help.KnowledgeBase.URL
- Help.KnowledgeBase.AdvancedOptions
- Help.KnowledgeBase.DeviceDriver
- Help.KnowledgeBase.Error
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
