Hewlett Packard 11691D
The Hewlett Packard 11691D device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 11691D:
The frequency range of the Hewlett Packard 11691D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 11691D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 11691D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
