Hewlett Packard 33120A
The Hewlett Packard 33120A device driver is a Signal Generator, Modulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 33120A:
The frequency range of the Hewlett Packard 33120A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 33120A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 33120A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Documentation
The manual of the Hewlett Packard 33120A can be found here
