Hewlett Packard 71100C
The Hewlett Packard 71100C device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 71100C:
The frequency range of the Hewlett Packard 71100C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 71100C.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 71100C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Hewlett Packard 71100C
- Google image search: Hewlett Packard 71100C
