Hewlett Packard 7401A
The Hewlett Packard 7401A device driver is a Spectrum Analyser which is supported by RadiMation®.
| Note: | General information of this device driver can be found on the Hewlett Packard 7400 Series page. |
The following tabs are available in the advanced configuration of the Hewlett Packard 7401A:
The frequency range of the Hewlett Packard 7401A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 7401A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 7401A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Hewlett Packard 7401A
- Google image search: Hewlett Packard 7401A
