Hewlett Packard 8447F OPT H64
The Hewlett Packard 8447F OPT H64 device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8447F OPT H64:
The frequency range of the Hewlett Packard 8447F OPT H64 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 8447F OPT H64.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 8447F OPT H64 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
