Hewlett Packard 8673C + 3314A
The Hewlett Packard 8673C + 3314A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard 8673C + 3314A:
The frequency range of the Hewlett Packard 8673C + 3314A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard 8673C + 3314A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard 8673C + 3314A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Hewlett Packard 8673C + 3314A
- Google image search: Hewlett Packard 8673C + 3314A
