Hewlett Packard E8257C
The Hewlett Packard E8257C device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hewlett Packard E8257C:
The frequency range of the Hewlett Packard E8257C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hewlett Packard E8257C.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hewlett Packard E8257C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
