Hughes 1177H01
The Hughes 1177H01 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hughes 1177H01:
The frequency range of the Hughes 1177H01 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Hughes 1177H01.
Be careful changing these settings as RadiMation® is no longer able to verify if the Hughes 1177H01 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
