Hughes 1177H03
The Hughes 1177H03 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Hughes 1177H03:
The frequency range of the Hughes 1177H03 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Hughes 1177H03.
Be careful changing these setting as RadiMation® is no longer able to verify if the Hughes 1177H03 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Hughes 1177H03
- Google image search: Hughes 1177H03
