IEC 61000-4-20
The EN/IEC 61000-4-20 standard describes how Immunity and Emission measurements are performed in a transverse electromagnetic (TEM) waveguides.
The exact title of this standard is: "IEC 61000-4-20: Electromagnetic compatibility (EMC) - Part 4-20: Testing and measurement techniques - Emission and immunity testing in transverse electromagnetic (TEM) waveguides"
This review is based on the Edition 2.0 2010-08 version.
Some random remarks and notes:
  • It is advised to not use EUT that are larger than 1/3 of the height of the usable height of the TEM.
  • For the Immunity testing, the standard describes that the Uniform Field Area in the TEM should be verified, using the procedures similar to as described in the EN 61000-4-3.
Emission[edit]
The TEM cell is a different and cost efficient method, compared to the OATS, to measure the emission patron of the EUT. This method does have a down side, calculation is needed to correlate the measurements done in the TEM cell to the OATS
For the emission tests there are 2 ways to calculate a correlation to the OATS:
  1. multi pole model
  2. three voltage measurements
Multi pole model[edit]
The multi pole model is currently not supported by RadiMation®
Voltage measurements: 3-Positions[edit]
Also known as the "To Radiated Power method". In this method the EUT is placed in 3 axis (x, y and z).
, and are the measurements done in Volt on the same frequency but in different directions.
is the Root-sum-square of the measured voltages.
is the maximum field in V/m
is the geometry factor determined by the height scan of the receiving antenna.
Related standards[edit]
Links[edit]
