IFI CMX 5003
The IFI CMX 5003 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI CMX 5003:
The frequency range of the IFI CMX 5003 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IFI CMX 5003.
Be careful changing these settings as RadiMation® is no longer able to verify if the IFI CMX 5003 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
