IFI DC500H
The IFI DC500H device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI DC500H:
The frequency range of the IFI DC500H as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IFI DC500H.
Be careful changing these settings as RadiMation® is no longer able to verify if the IFI DC500H is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
