IFI EFG-3B
The IFI EFG-3B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI EFG-3B:
The frequency range of the IFI EFG-3B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IFI EFG-3B.
Be careful changing these settings as RadiMation® is no longer able to verify if the IFI EFG-3B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: IFI EFG-3B
- Google image search: IFI EFG-3B
