IFI M404P
The IFI M404P device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI M404P:
The frequency range of the IFI M404P as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI M404P.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI M404P is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
