IFI S251-500
The IFI S251-500 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFI S251-500:
The frequency range of the IFI S251-500 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the IFI S251-500.
Be careful changing these setting as RadiMation® is no longer able to verify if the IFI S251-500 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: IFI S251-500
- Google image search: IFI S251-500
