IFR 2023A
The IFR 2023A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IFR 2023A:
The frequency range of the IFR 2023A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IFR 2023A.
Be careful changing these settings as RadiMation® is no longer able to verify if the IFR 2023A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
