IVW Diamond
The IVW Diamond device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the IVW Diamond:
The frequency range of the IVW Diamond as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the IVW Diamond.
Be careful changing these settings as RadiMation® is no longer able to verify if the IVW Diamond is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: IVW Diamond
- Google image search: IVW Diamond
