Immunity.Multiband.IsotropyGraph.Enabled
This advanced option specifies if the 'Angle' graph for the fieldprobe isotropy measurements should be shown in relevant Multiband Immunity tests.
By default this value is 'True'. The calculation and determination of the 'Angle' graph can take a long time, as for each tested frequency an seperate graphline needs to be calculated for all the graphlines that are available. We however will only do this for the 'Isotropy' measurements, so loading other data file are not influenced by this advanced option. The primary reason of an isotropy measurement is to be able to view the 'Angle' graph, thus that is the reason that the default is 'True'. However be aware that loading and calculating the isotropy 'Angle' graphs will take some time.
There are other advanced options available that are related to this advanced option:
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
