Immunity.Multiband.PowerGraphs.Advanced.Available
This advanced option specifies if more advanced power graph lines should be made available in any Multiband Immunity test. The default value of this option is False. When the advanced power graphs are made available (by setting this advanced option to True), the following power graphs will also be made available:
- Signal power at amplifier
- Forward power at coupler
- Forward power at amplifier
- Forward power at coupler monitor
- Forward power at powermeter
- Reflected power at coupler
- Reflected power at amplifier
- Reflected power at coupler monitor
- Reflected power at powermeter
- Net power at coupler
- Net power at amplifier
These graphs can for example be used to verify the corrections that are applied to the different components of the measurement setup.
Also see Immunity.Multiband.PowerGraphs.Standard.Available, which determines if more the standard power graphs should be made available.
This option is introduced in Version 2015.3.4 of RadiMation®, older versions are not able to show the advanced power graphs automatically.
There are other advanced options available that are related to this advanced option:
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
