Immunity.Multiband.Voltage.Analyser.Attenuation.Default
This advanced option specifies the default attenuator that should be set in the analyser by default when a voltage measurement should be performed in a multiband immunity test.
By default this value is set to 30 dB. The algorithm of the voltage measurement in a multiband immunity test is however able to modify the attenuation after it is initially set to get a more accurate measurement.
There are other advanced options available that are related to the measurement of the voltage level in multiband immunity tests.
- Immunity.Multiband.Voltage.Analyser.ReferenceLevel.Default
- Immunity.Multiband.Voltage.Analyser.Attenuation.Default
- Immunity.Multiband.Voltage.Analyser.VBW.Default
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
