Kalmus 116FC
The Kalmus 116FC device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 116FC:
The frequency range of the Kalmus 116FC as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus 116FC.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus 116FC is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
