Kalmus 122C (OCE BCI)
The Kalmus 122C (OCE BCI) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 122C (OCE BCI):
The frequency range of the Kalmus 122C (OCE BCI) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus 122C (OCE BCI).
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus 122C (OCE BCI) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Kalmus 122C (OCE BCI)
- Google image search: Kalmus 122C (OCE BCI)
