Kalmus 122C (OCE Low Band Antenna)
The Kalmus 122C (OCE Low Band Antenna) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 122C (OCE Low Band Antenna):
The frequency range of the Kalmus 122C (OCE Low Band Antenna) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus 122C (OCE Low Band Antenna).
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus 122C (OCE Low Band Antenna) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Kalmus 122C (OCE Low Band Antenna)
- Google image search: Kalmus 122C (OCE Low Band Antenna)
