Kalmus 711-FC-CE
The Kalmus 711-FC-CE device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 711-FC-CE:
The frequency range of the Kalmus 711-FC-CE as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus 711-FC-CE.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus 711-FC-CE is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Kalmus 711-FC-CE
- Google image search: Kalmus 711-FC-CE
