Kalmus 717FC (OCE High Band Antenna)
The Kalmus 717FC (OCE High Band Antenna) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus 717FC (OCE High Band Antenna):
The frequency range of the Kalmus 717FC (OCE High Band Antenna) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus 717FC (OCE High Band Antenna).
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus 717FC (OCE High Band Antenna) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Kalmus 717FC (OCE High Band Antenna)
- Google image search: Kalmus 717FC (OCE High Band Antenna)
