Kalmus Internal Coupler
The Kalmus Internal Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus Internal Coupler:
The frequency range of the Kalmus Internal Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus Internal Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus Internal Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
