Kalmus LA1000L
The Kalmus LA1000L device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus LA1000L:
The frequency range of the Kalmus LA1000L as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus LA1000L.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus LA1000L is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
