Kalmus LA2000F
The Kalmus LA2000F device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Kalmus LA2000F:
The frequency range of the Kalmus LA2000F as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Kalmus LA2000F.
Be careful changing these settings as RadiMation® is no longer able to verify if the Kalmus LA2000F is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
