Keylink microwave KB2060S46B
The Keylink microwave KB2060S46B device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keylink microwave KB2060S46B:
The frequency range of the Keylink microwave KB2060S46B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keylink microwave KB2060S46B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keylink microwave KB2060S46B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keylink microwave KB2060S46B
- Google image search: Keylink microwave KB2060S46B
