Keysight33400SeriesDriverConfiguration
Note: This page is used to show the configuration of the Hewlett Packard/Agilent Technologies/Keysight Technologies 34400-series multimeter device drivers. This page can now easily be embedded on all relevant device driver pages.
On the Settings tab, the desired communication method can be selected and configured. Depending on the selected method, additional relevant settings are shown and can be configured.
ScreenElementDescription.svg Use Remote Measure Settings If selected, the Keysight33400SeriesDriverConfiguration will be controlled by the driver to switch to the selected measurement mode. If this option is not selected, the end-user has to manually configure the Keysight33400SeriesDriverConfiguration to perform the correct measurement. This manual configuration can be useful to allow the measurement of period or capacitance, if it is supported by the multimeter.
ScreenElementDescription.svg AC volt (Vrms) Selects the AC volt measurement mode. The measurement result will be retrieved in the volt unit.
ScreenElementDescription.svg AC current (Arms) Selects the AC current measurement mode. The measurement result will be retrieved in the ampere unit.
ScreenElementDescription.svg DC volt (V) Selects the DC volt measurement mode. The measurement result will be retrieved in the volt unit.
ScreenElementDescription.svg DC current (A) Selects the DC current measurement mode. The measurement result will be retrieved in the ampere unit.
ScreenElementDescription.svg Resistance (Ohm) Selects the resistance measurement mode. The measurement result will be retrieved in the ohm unit.
ScreenElementDescription.svg Frequency (Hz) Selects the frequency measurement mode. The measurement result will be retrieved in the hertz unit.
When the Keysight33400SeriesDriverConfiguration is used as an AD convertor in RadiMation®, a few of the available channels in RadiMation® can be used to retrieve the value of the selected measurement mode. As the driver for the Keysight33400SeriesDriverConfiguration also supports continuous background measurement during the dwell time the channel 9 and channel 10 provide additional measurement results.
  • Channel 1: the last measured value of the selected measurement mode.
  • Channel 9: the minimum value of the selected measurement mode since the previous measurement.
  • Channel 10: the maximum value of the selected measurement mode since the previous measurement.
