Keysight Technologies AP5001A
(Redirected from Keysight AP5001A)
The Keysight Technologies AP5001A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies AP5001A:
The frequency range of the Keysight Technologies AP5001A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies AP5001A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies AP5001A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
