Keysight Technologies 33511B
The Keysight Technologies 33511B device driver is a Signal GeneratorModulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies 33511B:
The frequency range of the Keysight Technologies 33511B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies 33511B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies 33511B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
