Keysight Technologies 33512B
The Keysight Technologies 33512B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies 33512B:
The frequency range of the Keysight Technologies 33512B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Keysight Technologies 33512B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Keysight Technologies 33512B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Keysight Technologies 33512B
- Google image search: Keysight Technologies 33512B
