Keysight Technologies 33521A
The Keysight Technologies 33521A device driver is a Signal Generator, Modulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies 33521A:
The frequency range of the Keysight Technologies 33521A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies 33521A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies 33521A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keysight Technologies 33521A
- Google image search: Keysight Technologies 33521A
