Keysight Technologies 33522A
The Keysight Technologies 33522A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies 33522A:
The frequency range of the Keysight Technologies 33522A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies 33522A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies 33522A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keysight Technologies 33522A
- Google image search: Keysight Technologies 33522A
