Keysight Technologies 34401A
The Keysight Technologies 34401A device driver is a Multimeter which is supported by RadiMation®.
On the Settings tab, the desired communication method can be selected and configured. Depending on the selected method, additional relevant settings are shown and can be configured.
ScreenElementDescription.svg Use Remote Measure Settings If selected, the Keysight Technologies 34401A will be controlled by the driver to switch to the selected measurement mode. If this option is not selected, the end-user has to manually configure the Keysight Technologies 34401A to perform the correct measurement. This manual configuration can be useful to allow the measurement of period or capacitance, if it is supported by the multimeter.
ScreenElementDescription.svg AC volt (Vrms) Selects the AC volt measurement mode. The measurement result will be retrieved in the volt unit.
ScreenElementDescription.svg AC current (Arms) Selects the AC current measurement mode. The measurement result will be retrieved in the ampere unit.
ScreenElementDescription.svg DC volt (V) Selects the DC volt measurement mode. The measurement result will be retrieved in the volt unit.
ScreenElementDescription.svg DC current (A) Selects the DC current measurement mode. The measurement result will be retrieved in the ampere unit.
ScreenElementDescription.svg Resistance (Ohm) Selects the resistance measurement mode. The measurement result will be retrieved in the ohm unit.
ScreenElementDescription.svg Frequency (Hz) Selects the frequency measurement mode. The measurement result will be retrieved in the hertz unit.
When the Keysight Technologies 34401A is used as an AD convertor in RadiMation®, a few of the available channels in RadiMation® can be used to retrieve the value of the selected measurement mode. As the driver for the Keysight Technologies 34401A also supports continuous background measurement during the dwell time the channel 9 and channel 10 provide additional measurement results.
  • Channel 1: the last measured value of the selected measurement mode.
  • Channel 9: the minimum value of the selected measurement mode since the previous measurement.
  • Channel 10: the maximum value of the selected measurement mode since the previous measurement.
