The Keysight Technologies 34470A device driver is a AD Converter which is supported by RadiMation®.
On the Settings tab, the desired communication method can be selected and configured. Depending on the selected method, additional relevant settings are shown and can be configured.
Use Remote Measure Settings
If selected, the Keysight Technologies 34470A will be controlled by the driver to switch to the selected measurement mode. If this option is not selected, the end-user has to manually configure the Keysight Technologies 34470A to perform the correct measurement. This manual configuration can be useful to allow the measurement of period or capacitance, if it is supported by the multimeter.
AC volt (Vrms)
Selects the AC volt measurement mode. The measurement result will be retrieved in the volt unit.
AC current (Arms)
Selects the AC current measurement mode. The measurement result will be retrieved in the ampere unit.
DC volt (V)
Selects the DC volt measurement mode. The measurement result will be retrieved in the volt unit.
DC current (A)
Selects the DC current measurement mode. The measurement result will be retrieved in the ampere unit.
Resistance (Ohm)
Selects the resistance measurement mode. The measurement result will be retrieved in the ohm unit.
Frequency (Hz)
Selects the frequency measurement mode. The measurement result will be retrieved in the hertz unit.
When the Keysight Technologies 34470A is used as an AD convertor in RadiMation®, a few of the available channels in RadiMation® can be used to retrieve the value of the selected measurement mode. As the driver for the Keysight Technologies 34470A also supports continuous background measurement during the dwell time the channel 9 and channel 10 provide additional measurement results.
- Channel 1: the last measured value of the selected measurement mode.
- Channel 9: the minimum value of the selected measurement mode since the previous measurement.
- Channel 10: the maximum value of the selected measurement mode since the previous measurement.
Communication Streams
Expected response
The expected *IDN? response of a device. It can be changed in the case the commands are the same for another device for which no RadiMation® driver is available yet.
Restore default
Restores the original Exepected response.
