Keysight Technologies N4985A
The Keysight Technologies N4985A device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies N4985A:
The frequency range of the Keysight Technologies N4985A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies N4985A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies N4985A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
