Keysight Technologies N5171B
The Keysight Technologies N5171B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies N5171B:
The frequency range of the Keysight Technologies N5171B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies N5171B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies N5171B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keysight Technologies N5171B
- Google image search: Keysight Technologies N5171B
