Keysight Technologies N9000A controlled LISN
The Keysight Technologies N9000A controlled LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies N9000A controlled LISN:
The frequency range of the Keysight Technologies N9000A controlled LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies N9000A controlled LISN.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies N9000A controlled LISN is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keysight Technologies N9000A controlled LISN
- Google image search: Keysight Technologies N9000A controlled LISN
