Keysight Technologies N9320A
The Keysight Technologies N9320A device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Keysight Technologies N9320A:
The frequency range of the Keysight Technologies N9320A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Keysight Technologies N9320A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Keysight Technologies N9320A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Keysight Technologies N9320A
- Google image search: Keysight Technologies N9320A
