Laplace RF200
The Laplace RF200 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Laplace RF200:
The frequency range of the Laplace RF200 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Laplace RF200.
Be careful changing these settings as RadiMation® is no longer able to verify if the Laplace RF200 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Laplace RF200
- Google image search: Laplace RF200
